How to hide a parameter value in drawing
thlavinka
I have several model parameters that are shown in drawing BOM. Two of them are raw material dimensions and a standard (norm)
I would need to hide/dont show a value of the dimension in drawing supposing that the parameter standard is not empty.
Thanks in advance
Tom
RaphMORIN
(To:thlavinka)
You should manage to do this with relations in you parts. Something such as :
if standard == ""
     dimensions = ""
else
     dimensions = "what ever you want"
endif
6 REPLIES 6
RaphMORIN
(To:thlavinka)
if standard == ""
     dimensions = ""
else
endif
Can i ask for one more help?
I would like add next following relation to a subasm drawing:
if asm.mbr.nazev == "SVARENEC"
     asm.mbr.norma = ""
else
     asm.mbr.norma = &sheet_number
endif
where asm.mbr.nazev is a name of the subasm/part in BOM. In case of a subassembly the name is always "SVARENEC"
I would like to make a relation to have in the bom collumn a sheet number in case of subasm (svarenec) or a standard (DIN....) at parts in the same collumn.
It does not work....
Thanks for help
Tom
RaphMORIN
(To:thlavinka)
The syntax asm.mbr.something is used only in the table reports. For you relation you must write it with parameters like this for example :
if nazev == "SVARENEC"
     norma =""
else
endif
OK, and this relation should be in drawing bom table or each model of the subasm?
I tried both ways with no success
thanks
Not sure i understand the problem, but first, make sure you get rid of the ampersand (&). Second, make sure you get rid of the dots in the repeat region param names and replace them with underscorers (_).
if asm_mbr_nazev == "SVARENEC"
    asm_mbr_norma = ""
else
    asm_mbr_norma = sheet_number
endif
Third, depending on what version of Creo/Pro/E you run make sure all the parameters that are used, such as ASM_MBR_NAZEV, ASM_MBR_NORMA, SHEET_NUMBER are present in the repeat region parameter list.
It works....., thanks a lot
