I have several model parameters that are shown in drawing BOM. Two of them are raw material dimensions and a standard (norm)
I would need to hide/dont show a value of the dimension in drawing supposing that the parameter standard is not empty.
Thanks in advance
Tom
You should manage to do this with relations in you parts. Something such as :
if standard == ""
dimensions = ""
else
dimensions = "what ever you want"
endif
if standard == ""
dimensions = ""
else
endif
Can i ask for one more help?
I would like add next following relation to a subasm drawing:
if asm.mbr.nazev == "SVARENEC"
asm.mbr.norma = ""
else
asm.mbr.norma = &sheet_number
endif
where asm.mbr.nazev is a name of the subasm/part in BOM. In case of a subassembly the name is always "SVARENEC"
I would like to make a relation to have in the bom collumn a sheet number in case of subasm (svarenec) or a standard (DIN....) at parts in the same collumn.
It does not work....
Thanks for help
Tom
The syntax asm.mbr.something is used only in the table reports. For you relation you must write it with parameters like this for example :
if nazev == "SVARENEC"
norma =""
else
endif
OK, and this relation should be in drawing bom table or each model of the subasm?
I tried both ways with no success
thanks
Not sure i understand the problem, but first, make sure you get rid of the ampersand (&). Second, make sure you get rid of the dots in the repeat region param names and replace them with underscorers (_).
if asm_mbr_nazev == "SVARENEC"
asm_mbr_norma = ""
else
asm_mbr_norma = sheet_number
endif
Third, depending on what version of Creo/Pro/E you run make sure all the parameters that are used, such as ASM_MBR_NAZEV, ASM_MBR_NORMA, SHEET_NUMBER are present in the repeat region parameter list.
It works....., thanks a lot
