I need to import .prt file in solid works with minimum data loss and in editable format. Also with feature recognition as accurate as posiible.
I tried importing one .prt file in solid works but data and feature recognition is not properly extracted.
Please help me with this
You are in the wrong forum.
PTC has two CAD systems: Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Feature recognition is a solidworks feature, not a creo feature. You need to ask this question in a solidworks environment to get more helpful answers.
