How to know whether view has hatch lines or not
Ketan_Lalcheta
As we can use 2-D cross sections in drawing view, I would like to know whether hatch lines are present in view due to 2-D sections or not?
Please use below snap for reference:
This can be checked visually, but I am interested to know whether it is possible to find out same by any other means or not? I checked that same cannot be found from View info.
Any suggestion would be helpful on this.
Thanks and Regards
Ketan
Inoram
(To:Ketan_Lalcheta)
mouse over, pointer is there but not in screen capture. THen if you have them erased you can right-click and hit Show.
You can also use the Find tool to determine if a section is active in the drawing, make sure include submodels option is checked. You can also use it to select the xhatch and you can RMB to determine if the xhatch is shown or not. If there are no hatch lines but the RMB shows erase Cross Hatching as an option the hatch spacing is too large for the view.
