Hi everyone,
I’m working in Windchill with parts and drawings stored in my workspace. I’ve generated the drawing PDFs, and now I’d like to link all related information—such as design calculations, supporting documents, and relevant email correspondence—to the specific part in Windchill.
The goal is to have a complete design history or data package for each part, similar to how it’s managed in Teamcenter, where all associated files and communication are traceable and connected to the part.
What is the best way to achieve this in Windchill?
Is there a recommended workflow or structure to ensure everything stays linked and easily accessible later?
Any guidance or best practices would be greatly appreciated!
To add to what Ben said,
In Windchill, the WTPart is the central focus for a part number. Linked to that is everything that defines the part number (CAD models, CAD, drawings, documents, etc.). This would be your controlled documents that all get a unique document number and have version control.
You can also add what are known as "attachments" to CAD Documents. These files are directly tied to the CAD Model file. "Attachments" do not get document numbers and they don't have any version control. This might be a good solution for some of the things you mentioned like design calculations and emails. I don't believe you cad add "attachments" to WTParts.
A few additional comments:
You cannot attach those secondary documents to the CAD objects. This is where using WTparts comes into play.
If you have a WTpart for your top level assembly, then you attach the related documents in Windchill to that WTpart.
You can only have WTparts for parts and assemblies, not drawings.
Hello @AV_13191284,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
