Hi everyone,
I am new to Creo shematics and I have troubles making a simple splice on a wire. I precisely followed the indications in the doc page "To Insert a Splice" with no success; the cursor does not become "T shaped" as it is supposed.
I use creo schematics 2.0.
Any help/advice would be greatly appreciated.
you need to create block (with proper diagram type) which include three ports organized as following :
Gaby
Gaby
Thank you very much for your answer.
Is it possible to use a single dot style, like the documentation example in the section "About Splices"?
yes, just place the ports one over each other.
Hi, Unable to fine the video
