I have been testing out the search_path option to locate all my components of my assembly in PTC Parametric, but each time I have to consistently add my search_path again and again everytime I open and close my program. How do I make it so that the search_path of my assembly will always be active as soon as I open PTC and so that I won't have to add the same path again?
Alex,
You can create a search.pro and set config option search_path_file with value as search.pro (location and name).
there could be a few thing going on here.
quick question; when you launch creo are you using the default creo icon or have you created a unique desktop icon for that working directory?
can you describe how you are starting up your creo session more?
Alex,
to enable Creo to set search_path options during startup, put these options into config.pro file located in Creo2_LOADPOINT\Creo 2.0\Common Files\Mnnn\text directory.
Martin Hanak
