How to manually add models to BOM
wasim
2-Explorer
I have an assembly which consist of machined parts and standard parts (like screws, springs...etc) i need to make separate BOM for machined & standard parts, is it possible to do it by manually selecting the parts for different BOM's
dgschaefer
(To:wasim)
It's pretty easy to manually filter items out using the repeat region filters (I'm assuming you're talking about a drawing here).  Better would be to find a way to filter them by rule, perhaps your file names have consistent prefixes or you could create a Y/N parameter named "standard" in each part set to Y for standard parts, N for machined.  Then I think this will show only the standard parts:
&asm.mbr.standard  == Y
And this will only show the machined:
&asm.mbr.standard  == N
LinkedIn
dgschaefer
(To:wasim)
LinkedIn
wasim
2-Explorer
(To:dgschaefer)
Thank you for such imple explanation.
