How to move a sub-assembly from assembly to another
fdefilippi
Greeting-
I have a sub-assembly (a) within another sub assembly (b), and I need to relocate this out place it at the same level as assembly (B).  How best to do this as drag and drop don't work.
thank you
kdirth
(To:fdefilippi)
My guess would be that you have something in your top level assembly constrained to it.  Remove these constraints, move the sub-assembly, and recreate the needed constraints.
For whatever reason, CREO will not allow a sub-assembly or part to be relocated up when there are constraints in the upper level assembly referencing the sub-assembly or part.
4 REPLIES 4
kdirth
(To:fdefilippi)
Thanks Kevin, for some reason I was able to drag and drop in out of the assembly, after a few attempts and it kept the constraints as well.
Frank
kdirth
(To:kdirth)
You may also be able to move parts constrained to your sub-assembly into the sub assembly, move the sub assembly, and then move the parts back out.
thanks for the tips.. still on a learn curve with this s/w thanks for the patience.
