I have few images in sheet 1, I want to move them to other sheets. I don't see how this can be done, please help me.
Hello @IS_9869112,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry. You could add -
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team
Hello Vivek,
Its a .png image which is already there in my drawing sheet 1, I want to move it to sheet 2.
I dont see an option to move the image from sheet to sheet. How to do it? I cant even copy the image or save the image from my drawing to my desktop.
There is an option "copy from other drawing" but copy from the same drawing or moving to other sheets, I don't see an option.
can you please guide me here?
Best Regards,
Syed
@IS_9869112 wrote:
Hello Vivek,
Best Regards,
Syed
if you use Images command then you're out of luck.
You have to use Object command. Unfortunately this method may not work.
Object command works well with .bmp files. To move a picture from Sheet 1 to Sheet 2 use CTRL+X and CTRL+V (Cut and Paste functionality).
The only option I see is take the screen shot of the image, save it and then go to images and import it.
The suggested thing to do is to change the problem. Instead of trying to move the image from one sheet to another, it's being suggested that you look at it another way, and instead move the views around. Moving views is very easy, pick the view or views and then select Move to Sheet. So you're rearranging the views around where you want the images instead of the other way around. You can add new sheets as needed, move sheets around to "renumber" them, etc.
The easiest method may be to rearrange the sheet tabs (and rename) and move the views to the new first pages.
lol, moving the views is the challenge here. 😊
Yeah, it is kind of hard to select all of the views in the drawing tree the select Move to Sheet and select the new sheet. 😉
