Hi all,
I wanna create a Menu where I can to expand your options with click. Follow the image below:
I could do it.
I just created a menu type "menu" and other menu with the options "mashup".
I binded the menu "mashup" into the menu type "menu" and it work!
Thanks for your answer.
I could do it.
You may accept your answer as Solution for the post.
BTW was this query for Creo Parametric or ThingWorx?
ThingWorx
