Hi all,
Is there any way to print or create a pdf file for all drawing in a project? i still have to print one by one.
"The Pro/BATCH module allows the creation of export files without having to retrieve each object file independently during a session of Pro/ENGINEER"
<Load Point>\Parametric\bin\ptcdbatch.bat
Thanks LEONIDGUREVICH,
I haven't install Distributed Computing Extension before, so i can't find that file. After reinstall i can see it now but still can't export file, i need more time to investigate it.
By the way, is there any way i can show drawing of each item quickly on parametric window and don't need to find exactly file name in open windown?
Thanks.
I know how to print all file in folder folow your instruction, but i have other problem : in my folder, i store all drawing, but in my project, only some drawing use, and other don't show in project (part or assembly suppressed) and i don't want to print it. Is there any way to choose the right file i want to export?.
Ty
see https://community.ptc.com/t5/Creo-Modeling-Questions/Trailmaker-0-3/td-p/48278/page/2 discussion.
I attached the last version of Trailmaker that I have.
