How to "unlink" alike annotations in assembly with multiple copies of a part
JBen
Using Creo 8.0.5.0. So I have an assembly that contains 2 copies of a part. When I pull in dimension annotations to add to view states, since they are being pulled in from the part file, both copies of the part display the same annotations in exactly the same spot relative to the part. My question is can I "unlink" or separate these annotations in the assembly to be able to locate them in different places and view states relative to the part they define to clean up my view states better?
0 REPLIES 0
