How to regain the spool feature that was deleted
vrajan
Hi Guys,
I created a wire with the spool feature defining the required thickness, bend radius and color of the wire. Accidentally i have deleted the spool feature and saved it. Now my wire looks very thin than it has to be. I am unable to create new spool and assign it for that wire with the required thicknes. Please give me some solution to it.
Thanks & Regards,
Vivek Rajan
Dale_Rosema
(To:vrajan)
Have you purge your older versions?
(e.g. - works with both prt and asm)
File_name.prt.1
File_name.prt.2
File_name.prt.3
If not, just go back to an earlier version and open that version.
Thanks, Dale
