Is there a way to rotate the dimension text by 180°?
This is what I mean:
Old:
Rotated 180°:
I saw someone suggest to rotate the view 180° in a previous post but this does not work for me.
We are currently working with Creo 10.
Kind regards,
Jaime
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
You are correct, I will move the post!
Thank you for the feedback and instructions. 😊
i think it is not possible by config or dtl options.
The only way if the dimension line not vertical but a little bit slanted counterclockwise for example 0.1 degree
Then dimension text will be oriented automatically as you want
I tried the following based on your suggestion, but I don't get the solution I'm looking for.
Perhaps I'm doing something wrong, so below some images to show what I tried.
Is this what you meant?
Kind regards,
Jaime
Please see the attached video
I meant dimension line slant, not dimension text slant
This seems to do the trick! Thank you 😊
@Van_AG I think videos are set to be moderated, maybe the moderators don't get notifications, not sure.
@Van_AG wrote:
some video upload issues...
please see the cloud link
I never embed videos directly into the text of the answer. I always add them as an attachment.
Attached a video showing "attaching a video", Thanks for the heads up @MartinHanak
