We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
Folks,
I need tosave a Pro/E model as Encapsulated Post Script (EPS), Scale Vector Graphics (SVG), or Adobe Illustrator (AI) typefile. The resulting files MUST be in one of these threeVECTOR-BASED scaleable formats. There is an option in Pro/E to do a SAVE AS to an EPS file, but from what I can tell Pro/E is saving this as the raster version of an EPS file, and not the vector-based version of an EPS. As most of you probably know both formats (raster and vector) of EPS files do exist. I have alsotried placing a view of the model on a drawing as well to see if there are any methods there to output the file as requiredwithout any luck.
I would like to know:
I need to get this done ASAP. Thanks up front for your help.
Best Regards,
Scott W. Schultz
Principal Consultant
3D Relief Inc.
3700 Willow Creek Drive
Raleigh, NC 27604
(919)259-0610
Hello, I created yesterday an Idea.
I tested today Inkscape but the import from dxf made by Creo Parametric has some problem. Texts are shifted and zoomed. Logo of the drawing format is out of the format.
The saved svg seems cutted. How did you set Inkscape to work correctly?
Nicola
