I've created a bolt circle, but am unable to pick, or select it for dimensioning. Any suggestions?
Can you select it in the model tree to show the bolt circle dimension.
For some odd reason, PTC chose to make the bolt circle non-selectable. The best you can do is to show the dimensions for that feature.
You may want to vote on this idea:
i have same problem please i need more explanation , how did you do that
It is a shown dimension, not a created dimension. Select the view, then choose show model annotations and make sure you are on the dimension tab of the show model annotations box
i tried that but the problem still exist,
Is there a bolt circle dimension in your model? Is that dimension already showing on your drawing? You can only show a dimension once.
Also check to see if the dimension has already been shown and then hidden by looking in the drawing tree under each view/annotations for hidden dimensions
my model in attachment .if possible check it .thanks for help
Unfortunately I am still on CREO 2 and can not open your Creo 3 file.
