I need to show the weld sequence on one part of a large assembly. To make the information easier to read, I want to show the weld sequence on a detail view. However, "Show Model Annotations" on the Detail View says for Symbols "No annotations can be shown in the current sheet/view for the selected objects". I can only show the weld annotations on the General View (which is too large to be of any use on a printed sheet).
I have tried layer visibility (all weld features are in their own layer), but again, this only works on the General View.
I could manually create new weld annotations on the Detail View, but the weld and the annotations already esist in the model, so it seems stupid to have to re-create them by hand. How can I show weld annotations from the model on a Detail View?
[I'm running creo 5.05]
use partial general view instead of detail view.
Thanks @MartinHanak
Partial view did the trick. My tunnel vision was telling me I had to do it in a Detail View, but this works as well.
Cheers!
