How to split a normal (Non Repeat Region) table into more than 1 instances?
lpandya
As there is an option for paginating a Repeat Region Table, I am looking for same kind of functionality for drawing tables with no repeat region present in it?
How to achieve this? If this is not straight away possible in creo, then what might be the best possible work-around for this issue?
Lakhan
DonSenchuk
(To:lpandya)
Select Table > Copy > Paste > Delete unwanted rows/columns from each table separately.
Hi Don,
You actually have a good idea here and I thank you for that but we are looking for more of an elegant way to solve the issue.
Because we might have to handle this table afterwards if user deletes or adds more data into the main table.
Is there any other way?
James62
(To:lpandya)
You can save the original table to a file (*.tbl), but then you will have to remember there is one such table in your workdir for instance.
DonSenchuk
(To:lpandya)
Not that I know of. They still haven't given us a way to snap separate tables together, like at the tables' corners, after all these years. (At least as far as I've seen.)
