How to use Create Flat in the Dep View when using Annotation.
tbt
7-Bedrock
7-Bedrock
Is this command use for sheet metal only?
Can this command use for modelling?
mmaenpaa
(To:tbt)
Do you have the Sheet Metal module loaded in modeling? You have to go to the Applications tab and select Sheet Metal to access those tools.
You will find a different methods to unfold or create a flat pattern in there.
MIke
tbt
7-Bedrock
7-Bedrock
(To:mmaenpaa)
How to use Create Flat in the Dep View when using Annotation?
This command use for sheet metal.
I have the Sheet Metal module loaded in modeling.
I select Sheet Metal to access those tools.
I find different methods to unfold or create a flat pattern in there.
What is the minimum thickness for sheet metal?
jkramer
(To:tbt)
Supposing you don't have the full blown "Sheetmetal" module, but only "Basic Sheets": the Dep View > Create Flat is not available, because you'll need the (paid) Sheetmetal Module for that.
Workaround: make a Copy of your sheet part, use Parts > Unfold to unfold it, and make a View of that on your Drawing.
You may want to keep the Copy with your original part by creating a Container (in Modeling: Structure > Part & Assembly > More > New Container). A Container is a trick to put a part beneath another part, as if it were an assembly.
