If you drag this Lisp file on the Annotation Viewport, it will become available in the Toolbox as "get text from drawing".
It simply scans all text on a 2D drawing in Annotation, and shows them in a display window.
Hoi Jaap,
mooi je hier te lezen ![]()
Somthing similar in
Änderungsindex in Anno (PTC Engineering Solutions/) - Lösung vorhanden! - Foren auf CAD.de
even it is in german, Lisp is Lisp ![]()
Groeten Best regards
ah, cool, thanks for the hint! It may even be that I came across this lisp when writing my tool (long ago, forgot how I managed), I always struggle a bit when doing Annotation lisps. Especially the command
(setf textlist (sd-call-cmds (get_selection :focus_type *sd-anno-text-seltype* :select :docu_text :by_drawing_docu_rest :check_function #'(lambda (text-item)
is not something that's easily found in the documentation...
Regards, Jaap
