I have a requirement to create drop down lists for 2 parameters in CREO. The values of the drop down list for the 2nd parameter should change depending upon the value selected in the drop down list for the 1st parameter. How can this be accomplished?
Not possible. You can build your own custom interface in J-Link, VB, or C++, but you can't manipulate the content of restricted parameter lists dynamically, on the fly.
