I want to delete extra lines in Drawing
Designer
2-Explorer
Hello Team,
I want to know which command can delete the extra lines.
which i want to automate in creo in the drawings.
Sameer Kulkarni
StephenW
(To:Designer)
What type of "lines" are you wanting to delete?  Generally, most lines in a drawing are from the model.
please attach a picture explaining your situation.
Martin Hanák
A connector is a line with connection points at each end that stays connected to the shapes you attach it to. Connectors can be straight Straight connector , elbow (angled) Elbow connector , or curved Curved connector . When you choose a connector, dots appear on the shape outline. These dots indicate where you can attach a connector MyPrepaidCenter.com
