IFX Fastener placement references failure
CH_9983923
6-Contributor
Hi all,
I have been trying to create a library of parts for our company to use via Windchill. I have created all the parts via the instance creator and they all generated correctly and worked with the IFX tool when the files were local.
I then uploaded the files for all the components onto Windchill and it worked fine for a week or so. However, I have now run into an issue where the button head fasteners and nuts don't assemble via the tool for an unknown issue.
Looking into the error note it says the placement references are failing to work properly but I can't find anything different in the .dat files compared to other fastener files which are still working as intended.
They can be assembled manually from their location on Windchill so the parts work, just seem to fail when trying to use them with IFX.
I've attached the fastener .dat files used below on Creo 8.0.
Please let me know if there is a fix to get those files working as they are already integrated into some assemblies already so would rather alter them than have to create new instances if possible.
Many thanks
in your file 'EDALE_BTN_HEAD.dat' you specifiy the SURFACE=28 and AXIS=486.
I could found the SURFACE but not the AXIS inside your 'EDALE_BTN_HEAD.prt' file.
I could found an Axis with ID=454 and an axis with ID=71.
The ID of the 'A_1' axis feature is 451.
But I could not find an axis with id 486.
can you please try it again by using the AXIS=454.
Oliver Gräbner
B&W Software GmbH
6 REPLIES 6
I had a look to your dat files.
Please remove the additiional tabs and spaces at the end of your SURFACE and AXIS entry.
Make sure that the ids are correct and exist in you windchill fastener part.
It is also possible to  specify a name instead of an id.
Use creo option 'show_selected_item_id' set to yes to get the id of the surface and the axis in the tooltip.
See also: Fastener Data Files - Placement References
! Placement References
SURFACE  124  -12  PLACEMENT_SURFACE
AXIS     341   24  PLACEMENT_AXIS
I always recommend to edit the *.dat files with Notepad++ and display Tabs and Spaces.
The Plugin 'Columns++' with Elastic tabstops is also very handy.
Oliver Gräbner
B&W Software GmbH
Hi Oliver,
Thank you for the response and answers.
This has solved the problem with the nuts, however this has not helped with the button head screws.
I went through the file on Notepad++ like you suggested and removed the extra tabs and spaces.
I also tried changing the axis that it relates too by adding a new axis and updating the table accordingly but that didn't have an effect either,
The button head is also still failing to update the catalogue on windchill and not sure whats going on with that.
Many thanks
do you still get the message regarding 'AXIS, SURFACE, ORIENT' or do you have another problem?
Does the problem occure with all instances or only with some special sizes?
E.g. the 'M5x40_BUT' was created from another template than the 'M10x20_BUT' and has different reference ids.
Please send me a screen shot of your IFX fastener dialog and the trail.txt file, and some of your instances, the I will try it on my end where the problem is.
Oliver Gräbner
B&W Software GmbH
Hope you had a good weekend!
Yes I still get the original issue with the axis, surface and orient for the Button heads.
It occurs with all the instances as they are came from a single template and follow the data table that was sent before.
I've attached a folder with screenshots of multiple error messages, the trail.txt file, the original part and then 2 of the instances created.
(The original does not have an axis added to it like the instances as they were changed to try and fix the issue.)
Many thanks
Oliver Gräbner
B&W Software GmbH
Axis 486 was added manually to the parts created via the IFX tool due to already being integrated into previous assemblies.
The issue has been solved but to be honest I'm not exactly sure how.
I updated the .dat file to use the Axis 454 and then Axis 71 as the issue was still there.
I then changed the name of the fastener on the .dat file and the catalogue file and reverted back to Axis 454 and now it works without issue.
However, it is now solved so thank you for your patients and help.
