Iges file used surface extraction process without import file reference how to create solidify part
pshinde-3
I want to create solidify surface by used import file of plastic interior part.
4 REPLIES 4
Pratap,
Explain this in detail.
There is Import Data Doctor (IDD).
You can modify the definition of the import part and manipulate it.
It is not easy and it is not a magic bullet.
It just lets you manipulate the surface geometry.
Pratap,
Attached is a PDF and sample file I use with my Creo college students.  It explains how to work with Import Data Doctor (IDD), specifically with Creo 3.0.  If you are using a different release of Creo you may, or may not need to adjust for changes in the menu
Hope this helps
I have one IGES format Plastic interior component "A' style surface so, I want to create into parametric model. it means B offsetting surface ( For certain Thickness) and 'C' closed surface and solidify so, How can I used Import file and create the part without the import date reference.
