Images in assembly
C-R
3-Newcomer
3-Newcomer
Images in assembly
Good evening,
in an assembly I have to put a model twice with some pictures (identical in each model). The problem is that the images appear in a single model.
Is there a way to see the images in both models?
Thanks a lot
TomD.inPDX
(To:C-R)
Not a problem I am familiar with but what if you change the name of the second image?
It might be worth making a support case if this is highly reproducible.
C-R
3-Newcomer
3-Newcomer
(To:TomD.inPDX)
I have already opened a case exposing this issue but they have said it is a setting of the program and you can not show both models with pictures.
The name of the images does not center because I already tried to change and nothing in assembly changes.
TomD.inPDX
(To:C-R)
That surprises me.  I have not tried this scenario or limitation.  How exactly is your assembly set up?
Normally, a support tech will state that a function works to specification.  If you are not satisfied with the reply from support, it can be escalated until you understand exactly what the problem is.
You have the option of creating a texture of your image and applying it to a surface feature or face on a solid.
There are decal textures that are easily generated that allow transparent backgrounds.
