Implications of increasing Java Heap size in Intralink 3.4
bbailey
8-Gravel
Hi All,
We have some pretty large assemblies (6-10G) and have recently upgraded to
Wildfire 4.0 M130 with Intralink 3.4, M062. Our standard PDF and HPGL
creation routines have been failing on our largest objects since the
switch. Our standard workstation has 8G RAM and we recommend twice that
for swap.
I have discovered that one can increase the Java Heap size in the
Intralink startup file. I have doubled the default values on a test
system, and all now appears to function normally.
My question is, what are the implications of doing this across the board
on all our Pro/Intralink 3.4 clients and has anyone already done something
similar?
Ben
0 REPLIES 0
