Add a comment to model tree item?!
jnanesh.sajjan
Hi all,
I am not sure if this option exists in Pro-e, but, let me ask!
Is it possible to add a comment to one of the model tree item? If any
user hovers the mouse over that item on model tree, a balloon should
pop-up and tell the story.
You can treat this similar to something like inserting comment in a
spreadsheet cell.
Thanks & Regards,
Jnanesha KS
T 91-80-4119 0900 Ext: 466
F 91-80-41190901
M 994 500 4179
Quality Engineering and Software Technologies
No 55 l QuEST Towers l Mahadevapura l Whitefield Main Road
Bangalore l 560048 l www.quest-global.com
Hi Jnanesha,
You can add notes to features or components in the model tree. If you RMB
on the feature or part and select the add note option you will see what I
mean. The tree then shows there is a comment there but this does not pop up
as it does in Excel. You can call these note up in a drawing.
Please remember that you need to have your tree.cfg set so that you see
everything or at least the notes. I prefer to have the tree set to show all
details and not have anything hidden from what I do as is the default.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
On 22 June 2010 16:30, Jnanesha K S <-> wrote:
> Hi all,
> Is it possible to add a comment to one of the model tree item? If any user
> hovers the mouse over that item on model tree, a balloon should pop-up and
> tell the story.
> spreadsheet cell.
> Thanks & Regards,
> Jnanesha KS
> F 91-80-41190901
> M 994 500 4179
