Community,
I import CATIA a file into Creo Parametric and I'm able to open it but the geometry doesn't looks good, it shows as a surface not a solid and also some surfaces are not connected (that's why is not a solid) when I review it on CATIA it shows as a solid, I try it with a native CATIA file and a step file and I have the same issue.
Any idea or suggestion?
Accuracy settings may be causing gaps to the imported model.
How complex is the CATIA model?
How many features?
What versions of CATIA and Creo?
Yes, I had been playing with the accuracy, It improves but I have not found the correct number.
It's complex, It's a full roof assembly has some details (fillets, etc) that are the surface issues I see and also some surface joint issues, I keep trying to work separate with each part to see if I can solve it, The version of CATIA is V5 (2018) and Creo 4.17.0, I don't have CATI software to see how many feature they are, I request to the team share the CATIA file this information as soon as possible I got it I will share it.
