Importing Parasolid (x_t) causes Creo 5 to Crash! Help!
I am running Creo 5.0.4.0 on Windows 10.
I am trying to open a standard parasolid file and it causes Creo to freeze while loading (spinning wheel of death). Shortly after, Creo stops responding and crashes.
I have tried this on another coworkers computer with the same setup as me, and it crashes for him too. Has anyone seen this before? I read online that you should be able to open x_t filetypes, but this seems to not be the case for me. Please help!
StephenW
StephenWAnswer
You may want to try NOT loading any configuration files. Rename any config.pro and/or config.sup.
This will bring you back closer to an out of the box scenario.
If you can attach the file here, I would be happy to try. I'm on Creo 4 (not 5).
It's possible the file is a bad export. If you have another cad software, try importing.
I have created exports that have been too complex or large. I have also received them. Sometimes you have to work with the file provider to get the right recipe and strike a good balance
StephenW
StephenW23-Emerald IIIAnswer
