Importing .sat files in v19
lbenjamin
7-Bedrock
Can someone tell me what happened to the ability to load/save .sat files in Creo Elements Direct Modeling. I went to load a .sat file today and did not even find it as an option - it was there in v18... Did I miss a check box in the install??
2 REPLIES 2
Lynda,
This post is realted to Creo Elements/Direct, moving the post to Creo Elements/Direct
Never mind... I found that I had not checked all the interfaces I wanted (like .sat, .stl, SolidWorks, etc) under the 'Data Interfaces' section of the 'Startup...' section of the Modules setup.
