Hi
We are importing Pro E files into UG NX 7.5, can some experts in this forum give some guidance ?
1. For parasolid - Assembly structucture is lost once it is imported into UG
2. JT does not seem to be viable option as well
3. Third party connectors supplied by either of the vendors seems a feasble option as well
4. Step seems to be the best approach, can some experts in the forum share the best way to export the Step file from Pro E such that all the information including the surfaces/solids are retained in step file when it is imported into UG ?
I think you beter post this in the Creo Parametric forum. this forum is dedicated to Creo Elements/Direct products.
