In 2D Creo drawing, How to automate centre line for hexagone
AB_10736884
While creating a 2D drawing, how to achieve to have a default automated center line for oblong rectangle or hexagon
StephenW
(To:AB_10736884)
@AB_10736884
If there is no axis in the model, there will be no centerline in the drawing. In the model, there is no default axis for oblong, rectangle or hexagon.
During feature creation of the  oblong, rectangle or hexagon, you can add and "point"  and when the sketch is extruded, it will create and axis. That can be the axis you can show in a drawing.
4 REPLIES 4
Hi @AB_10736884,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
StephenW
(To:AB_10736884)
@AB_10736884
@StephenW Thanks for workaround.
KenFarley
(To:StephenW)
Decades using this software and I never knew that. Used Geometry CSYS a lot but never thought to try a Geometry Point. An easy way to put an axis at the point in a slot where the default fastener location is. Nice.
