Increase Scale of Model for Proposal Purposes
LeeCasey
2-Explorer
Hi, sometimes I am creating proposal drawings. Components have not yet been spec'd or sourced. I might have a tank and a pump, I can easily increase the size of the tank to suit the customers needs, but I just want to scale the pump assembly (or part) to suit the new size tank without changing all the dimensions. Is this possible to do?
Hi
Have you tried Edit> Scale Model (in WF5) or
Model>Operations>Scale Model (in CREO)
to scale a part?
Regards
K.Mahanta
dhermosillo
(To:LeeCasey)
I think you mean to scale all of the components of an assembly together correct?
Sadly it can't be done in Pro/E:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=34150
However, if you have Mechanica, the comment at the end of this thread offers some hope:
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=40810
