Guru's, A bit off total really after advice / standards really. We are currently looking into gonig over to injection moulded parts for some items on our products. How ever the question I am really wanting an answer too is regarding model set up and what are the thought on drawings?
Our current thoughts are either a full dimensioned drawings& models, or aminamal drawing and model.
also what are the views on holes sizes etc on models, ie how do you show tolerances etc, are holes modeled top end, lower end of tolerance or the mean?
Might be simple questions but not had a great deal of experiance of using models to manufacture moulded parts
cheers
Colin Down
Design Engineer
Colin,
In my experience,I have always included all draft and fillets inmy models, and the models are always constructed to nominal dimensions. You need to include things such as draft 7 radii, to check for clearences between mating parts, and to watch out for die-lock conditions, material flow, and possible sink marks. Our drawing usually have minimal dimensions. We include overalls, and dims to locate any holes and locators. Include a general note on your drawing that says to refer to cad data for any dimensions not shown.
My 2 cts...
RE: "Shrinkage"
Designed a thin-wall (.020") trigger sprayer housing for a snap fit. Basically created the Pro/E model geometry such that the front end was actually splayed out 10 degrees more than the required finished part. This was "Kentucky windage" on the Pro/E geometry for the mold such that after injection and cooling, the part front end shrunk back to its design intent...
