Interchange Assembly Management with Windchill PDMLink
inancakgul7
Hello dear members,
I am using interchange assemblies with Pro/Program to create configurable assemblies.
I have an start assembly which contains roughly 30 parts. What I do, create diffrent configuration on the assembly using interchange assembly with Pro/Program functionalitiy.
And I have 30 diffrent interchange assembly for each parts of this start assembly. I just replace each component froma spesific interchange assembly.The problem is once you use a interchange component in the start assembly, the interchange assembly are used as reference by the start assembly which causes a huge referens problem.
After you create your own configuration and then check-in them commonspace then if you try to downloadand check-out this assembly toyour workspace, all interchange assemblies referenced (which is a carzy big) comes along with.
This is a big obstacle I have and dont know how to deal with it. Thank you in advance for your advices.
0 REPLIES 0
