Intralink scripting - updateDependencyParent question
lylebeidler
Intralink 3.4 scripting question.
In the Duplicate dialog box, up at the top is the Update Parents section.
When I record my interaction with this section, by doing RMB > Select All >
Yes, the resultant code as recorded is this:
private void run0 () throws Exception {
IL.openWindow( "DuplicateObjects", ", " ); // recorded step: 1
IL.duplicateObjects( "*.*", "*_.*", null ); // recorded step: 2
IL.deselectAll( "PI" ); // recorded step: 3
IL.updateDependencyParent( "q-28943/82463-28943.drw" ); // recorded
0 REPLIES 0
