Is it possible to automate adding a layer to hundreds of existing models in an assembly?
Inoram
thanks!
MartinHanak
(To:Inoram)
Inoram
(To:MartinHanak)
I forgot an important detail, the layer added will be different for every model (it would be the model name).
That sounds very non-logical...
What are you trying to accomplish with those layers?
Inoram
(To:HamsterNL)
CAM software uses layer names instead of model names. So when people import an assembly they can see what the name of everything like we see it as model names. A solid geom layer with model name as layer name would import into CAM.
If your top-level assembly has a layer with rules, you can "extend" it to all sub-components that do not have such a layer, meaning it will be created in those sub-components along with the rules.  This function is in the layer tree, in the dropdown decorated with the "stack of layers" icon (next to the hammer + wrench icon)
