Our old Autocad titleblocks were yellow so I imported the titleblock into a format but I can't figure out how to not print it in gray. The gray it too light to read.
I then changed the titleblock in Autocad to white thinking it would import it in white....but it imported the titleblock in black so I can't see it on the screen.
The drawing dimensions are yellow and they print in true black.
What's the best way to import a titleblock so it prints in true black like every other program in the world?
And I should mention that I do not want to manually create the titleblock in Pro/e.
I am using WF5.0.
Thanks!
David,
after importing titleblock into a format, you have change its color in ProE.
When you import titleblock then ProE assigns so called USER color to all titleblock items.
If you assign Letter color to all titleblock items then it will print using the same color as dimension witness lines.
If you assign Geometry color to all titleblock items then it will print using the same color as visible model edges.
Martin Hanak
