All
Just wondering if anybody else has come across this issue...
I am trying to save a copy of an assembly and simply give the assembly a new name, i.e. all of the components within the original assembly will be reused in the new assembly. There is one part within a sub-assembly for which I can neither reuse in the new assembly nor save a copy of to be used in the new assembly. If I select to save a copy I get the attached error message.
I have checked each feature within the problem part and there are no external parent references to any other part that I can see. Also, if I try to save a copy of the sub-assembly on it's own there are no issues, wworks fine...and if I put the sub assembly into a new assembly file and try to save a copy of that again there are no issues.
Anybody have any sugestions as to what I can do to try and resolve this?
Running Creo 2.0 m120
Thank you.
Neal
