I am working to generate a more accurate 3D model of a circuit board, using 3D components downloaded from supplier websites.
Since I am new to PTC Creo 3.0 (I have an electrical background), I am having a difficult time replacing the original parts with the parts that I downloaded from the supplier's websites.
Here is my process, that I learned from some instructional videos online:
The issue that I am running into, is, when I hit OK, the component is not being replaced in the same location as the original component. It is being placed off to the side of the circuit, with the movement capabilities added to it (I am within Component Placement). And when I hit the Green check mark, after dragging it to my desired location, it disappears
<- the component isn't in the location of the component I wanted to replace it with.
Any help is greatly appreciated
Nicholas,
Could you please upload the models that you are working with? It may not be necessary for you to use the Reference Table, but I will have a better idea after looking at the actual models.
Take a look at the following link for attaching files:
How to Attach a File to a Discussion Reply
Amit
Amit,
Thanks for your response. Unfortunately due to the confidentiality of my PCB, I am unable to upload the model online. Do you have any suggestions that you can make based on what I have already posted?
Hi Nicholas,
Try doing the following:
