All;
Has anyone run into an instance where a part file is sized in CM and when exported as an IGES or STP it maintains its physical size but when output as an STL format for prototyping the SLA model physical size changes/increases? Crazy but I ran into this today with some parts that we had built and traced the issue back to the native file which appears to be fine unless you export it as an STL??? Does anyone have an idea on what would cause this and more importantly, how to fix the issue going forward? I look forward to your experienced and productive input.
Thanx
Bruce
