Here is my scenario
What am I doing wrong?
Additionally, in CATIA V5 there is a solid called PartBody. This PartBody contains the CATIA V5 solid that I want to import into CREO 3.0. This PartBody in CATIA can contain a solid that is separated and not continuous. Think of a solid seat track that has a part of it removed. See attached picture.
This part is a component of a CATIA V5 Assembly.
when I import the CATIA V5 Assembly, which contains the part above, CREO 3.0 turns this CATIA V5 part into a CREO 3.0 Assembly with each of the sections of the original CATIA V5 part as a separate part in CREO. And the CSYS also show. See picture below:
Any suggestions?
