Issues with adding section views in Creo 2.0 on Elements legacy drawing
dmeschberger
I've got an issue where I had a Creo Elements 3D with alot of surfacing used for creation. When we took it into Creo 2.0, I found I had troubles adding new section views (in view manager), without "blowing up" solidified features & surface editing items. I tried rolling the model back to theimported feature, to see if adding the section views there, would avoid the "blow ups". Has anyone seen this issue and/or found work arounds?
I would be interested in knowing what the model looks like. Do you have
surface modeled geometry, or is this solid modeled geometry? Did you import
features from another model?
Michael P. Locascio
