How can I create letter groove cuts wrapped on round surface, using CREO 4?
if you ask Google ... Creo letter cuts curved surfaces
you will get following link
https://www.youtube.com/watch?v=hUMUiRbDJA4
use Wrap feature.
Thank you for reply, but how can I do this text about .030 deep cut?
Searching on "text", "curved", "surface", I came across this post:
Thank you very much Martin, that what I was looking for, keep up the good work.
Type "Creo letter cuts curved surfaces" or something like that into your search engine of choice and away you go.
