Light wight Assembly /Exporting assembly
MB_10357724
I created a subassembly that I wanted to export for the top-level assembly. Since the subassembly file size is huge, I can't use it directly in my top-level assembly.
Could you please suggest if there is a way to export the assembly (envelope) parametrically so that I can use it in the top-level assembly?
tbraxton
(To:MB_10357724)
One option is shrinkwrap.
Article - CS29678 - How to export an assembly model as a solid model or shrinkwrap in Creo Parametric
If you are in Creo 11 then check this out:
Multibody Support in Shrinkwrap Feature
Involute Development, LLC
Consulting Engineers
