Limiting sheetmetal thickness value!
jnanesh.sajjan
Hi All, again!
I am working on some sheet metal project. I would like to set some constraint such that any person in my team who will work on this project can not use sheet metal thickness more than 2mm.
Any way to do this?
Thanks and regards,
KS Jnanesha
Sr. Designer - Rockdrills
Atlas Copco AB
Should I assume no one has idea about this?
Cheers,
KS Jnanesha
KS Jnanesha,
If you create a restricted parameter file with the following entry
{ Name = smt_thickness
Type = real
Default = 1.5
Range = [ 0 , 2 ] // 0<=value<=2
Then the user will only be able to have a thickness of between 0 and 2,
if he tries to modify above this then he'll receive the below error.
Regards
Iain
