Line Style File "......" not loaded
ptc-4379105
How do I setup Creo to look at the folder with the line style files?
How do i change a drawing to remove use of a customised line style files?
Nathan,
1.)
In the past files containing line style definition had to be located in current working directory. There was no configuration option enabling access to "line-style-definition directory".
2.)
I guess you have to manually modify line styles in the drawing...
Martin Hanak
Martin Hanák
You can create the line style in template drawing file from the creo load point directory or can make uour own customized template drawing with customized line styles. When creting drawing by that template, the line style will appear.
