Lines in Imported Parts
mwimberly
I am sure that I am not the only that has this issue so I am bringing it to you all. I have files that I have downloaded from different websites and they have grey lines that show up at all times. Since the file only has a single feature I can't simply add the line geometry to a layer and turn them off. As a matter of fact I cannot even select them because they are part of the overall single feature. What has been done or can there be anything done to remove them from display?
[cid:image001.png@01CB4A92.D0224AA0]
Michael Wimberly
Engineering Applications Support Specialist III
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 833-3565 Mobile
(513) 881-5087 Fax
-<">mailto:->
P Before printing, think about the environment.
1 REPLY 1
As long as I have been using this you can learn something new every day. The .dtl file option mesh_ surface_ lines to off is the solution in the drawing. That is the main thing right now but I still taking suggestions on how to remove them from them model.
Michael Wimberly
9113 Le Saint Drive
(513) 881-5087 Fax
-<">mailto:->
