Local cache issue.
WC_13428467
Local cache issue.
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
Good morning, I am having an issue with my workspaces in Creo. The error 'local cache contents need to be synchronized with the workspace' appears when I try to check parts in to Windchill. I have already tried the synchronize button in the workspace. If I create a new workspace, the issue goes away for a while, but then comes back.
Will Collier.
Here are the errors that I faced
1 REPLY 1
Hi @WC_13428467
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Can you describe the steps you have taken to synchronize the local cache with the workspace in Creo?
  • Are there any specific error messages or logs that provide more details about the synchronization issue?
  • You mentioned that creating a new workspace temporarily resolves the issue. How long does this solution typically last before the problem reoccurs?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
